The differential equation for wheel speed can be given as:
In here, $T_t$ is driving torque (not braking), $F_x$ is longitudinal force of tyre, $J_w$ is wheel inertia, $\dot{w}$ is angular speed of wheel and $Frolling$ is rolling resistance force.
According the equation, if we increase the resistance force, $\dot{w}$ should increase. Increasing of angular speed may cause higher slip ratios. As long as longitudinal slip ratio increases, it is possible to have higher longitudinal tyre forces according to Magic Formula.
In here i have a confusion: High rolling resistance makes possible to have higher longitudinal force according to this differential equation. How can it be possible? How can $F_x$ increase with higher values of rolling resistance? If $F_x$ becomes high, it is impossible to decrease the vehicle. With the help of the positive and high $F_x$ force, vehicle cannot decelerate.
Thanks,
