For the problem below, I tried solving it, but I don't know where I should get the value of normal acceleration, guess I was lost.enter image description here
enter image description here And here's what I solved so far enter image description here
You are almost there.
In order to calculate the tangential and the normal acceleration you need to take them as vectors.
The angles are
  • $\theta= \arctan(16/12)=-53.13 deg$ for velocity
  • $\phi= \arctan(16/12)=-26.51 deg$ for accelaration
Therefore the vectors for acceleration and velocity would be
And then you can find the component of tangential and normal acceleration as:
  • tangential: $a_t =a \cos(\theta-\phi)$
  • normal: $a_n =a \sin(\theta-\phi) = 5\frac{m}{s^2}$
Then you can just substitute:
$$R = \frac{v^2}{a_n}= \frac{20^2}{5}= \frac{400}{5}= 80 in$$
  • $\begingroup$ Help appreciated, arigatou $\endgroup$
    – keplerxx
    May 13, 2021 at 13:29
  • $\begingroup$ Itsu demo dohzo $\endgroup$
    – NMech
    May 13, 2021 at 13:55
