In the design of boat hulls (and aircraft) reduction in material thickness is important and the hull is usually made as an assembly (welded or riveted) with stringers and frames. The design of stiffened panels is a complex problem. Are there a set of simplified rules for the design of stringers and frames for boat hulls?
$\begingroup$ Geodesic construction? but not sure if that is used on boats... $\endgroup$– Solar MikeMay 13, 2021 at 8:37
$\begingroup$ @PhilSweet If you convert your comment into an answer I can accept it. I didn't know the term scantling and now the search engines are working for me. I knew about BV & Lloyds but they work on something bigger than what I was looking for. Gerr's book (from what I've seen in "Look Inside") is what I'm looking for and is affordable. $\endgroup$– D DuckMay 13, 2021 at 8:56
1 Answer
They are called scantling rules. Herreshoff and Nevin had scantling rules for wooden yachts. Classification Societies such as Lloyds and BV have scantling rules for ships. Gerr's Boat Strength has rules for small boats covering several hull materials.
$\begingroup$ And as steel strength is increased ,be sure to specify higher toughness . The Coast Guard has rules for ship design and materials to be used in US waters. $\endgroup$ May 13, 2021 at 14:16
