Does anyone know if hollow sliding/pocket doors have a weight/more dense wood at the bottom of the door to prevent from swinging?
  • $\begingroup$ Some have guides or rollers. $\endgroup$
    May 11 '21 at 5:53
  • $\begingroup$ Do some also have heavier weight distributed at the bottom of the door or would that not serve much purpose? $\endgroup$
    – Dmitriy
    May 11 '21 at 5:57
  • $\begingroup$ Take the door off and find the balance point. You will soon know. $\endgroup$
    May 11 '21 at 5:59
It won't help prevent swinging, and in all likelihood would keep the door swinging longer after an impulse force is applied. As the comments suggest, most inside doors have a guide on the floor (usually in the retracted region, not the doorframe itself).
If you have a barn-door-type sliding door, there may well be a guide/stabilizer near the top of the door.
They do not. No one is really that concerned about it, and weight doesn't stop things from swinging, it just increases the period of the swing.
