If you are asking why does the 1 kg mass (I'll denote it as $m_1$), moves towards the inclined plane, then IMHO the exercise you shouldn't have any friction.
- If there is no friction, then the $m_1$ will move downwards, because there will be no horizontal force to keep it attached to the Wedge (I suspect its mass is 5 kg, so I will denote it as $m_5$. Below is the FBD and the kinetic diagrams of the two moving masses $m_1, m_5$.
The acceleration of mass 1 will be downward, while the wedge will accelerate in a direction along the plane.
- If there is friction, then the material will probably never meet the inclined face. The reason is that the friction will be the only force on the horizontal plane, so the $m_1$ will move with $m_5$. (Of course, if you change the slope you might get a reaction so great from the wall, that the friction cannot overcome).
If you are asking about the forces, then in order to calculate the reactions and the acceleration you'd have to solve the following system
$$\begin{cases}
- m_1 \cdot g + N_1 = -m_1\cdot a_1\\
- N_{2x} = - m_5\cdot a_{5x}\\
-m_5 g + N_{2y} - N_1 = - m_5\cdot a_{5y}\\
a_1 = a_{5y}\\
\frac{A_{5x}}{\cos(\phi)} = \frac{a_{5y}}{\sin(\phi)} = a_5\\
\frac{N_{2x}}{\sin(\phi)} = \frac{N_{2y}}{\cos(\phi)} = N_2
\end{cases}
If you do the substitutions you obtain the following system with 4 equations and 4 unknowns $a_1, a_5, N_1, N_2 $:
$$\begin{cases}
- m_1 \cdot g + \color{red}{N_1} = -m_1\cdot \color{red}{a_1}\\
- \color{red}{N_{2}}\sin(\phi) = - m_5\cdot \color{red}{a_{5}}\cos(\phi)\\
-m_5 g + \color{red}{N_2} \cos(\phi) - N_1= - m_5\cdot\color{red}{ a_{5}}\sin(\phi)\\
\color{red}{a_1} = \color{red}{a_{5}}\sin(\phi)\\
\end{cases}
The results (using g= 9.81 $m/s^2$)should be:
- $N_1$: 5.834 N
- $N_2$: 43.82 N,
- $a_1$: 3.975 $m/s^2$
- $a_5$: 6.6 $m/s^2$
I'll leave the numerical solution to any interested party.
