At first I want to apologize while English is not my first language.
I am a student, and I have to design such configuration:
I already have designed the "fork" (the part on the right side). Now I am at the point of calculating for the clamp band which is one part with a steel rib ($a$ dimension).
My problem is that I do know that there is a torque caused by force F and the torque caused by friction forces between the clamp and the shaft neck (where $R$ dimension is), I have to find force values that causes that torques zero in the assembly and then I have to transform those Friction torque to find a suitable screw that will stand the coaxial force caused by clamping, but I am probably overthinking this problem because I am thinking like this:
When the structure is clamped there is a coaxial force in the screw that is causing radial forces to form and is causing the change of radius that is different in infinite points on the inner circle. Now the radial forces wont be the same in whole area that is holding the shaft neck because half of the band won't deflect, so apportionment of the forces (their value to be precise) will change with the deflection of the band - so the force is linked to Δr.
Because of the above the resultant of the radial forces on each of the quarters of the band wont be located on the inner circle with the tilt of 45° and -45°. So, because of that for now I have such variables:
X- coaxial strength in screw,
Δr - change of the radius when the band is clamped - different in all areas where band is flexible.
y - variable that depicts the level of tightening the screw in mm
Fr - radial forces linked to X,y and Δr.
$\alpha$, $\beta-$ degrees that are depicting in what points on the inner circle resultant Fr is hooked
T - friction force caused by Fr
So this picture, pretty accurately depicts what I have in mind:
I know that this is complicated and probably impossible to calculate with my level of knowledge, so I am asking for help because I can't figure out what I can do here to actually calculate it.
I was trying to find some examples how to handle this but there is nothing helpful on the internet and it's unfortunate since it is quite easy for me to get "things" when I see examples.
