Is this a picture of a plate girder train bridge or a deck truss train bridge?
1$\begingroup$ It is a truss bridge. A plate girder is a solid I beam fitted up by plates for flanges and web. $\endgroup$– r13Apr 25, 2021 at 19:14
1$\begingroup$ The part of the bridge to the left of the stone masonry pier in the photo is a steel deck truss rail bridge. The part of the bridge to the right of the stone masonry pier is a timber/wood girder on timber bents/piers. A plate girder is usually an I beam where the flanges are either welded/bolted/rivetted to web. Deep girders and bridge girders tend to be plate girders. I beams for buildings and lighter loads tend to be one piece of steel and will be what is referred to as a rolled section as passing the hot steel through a series of rollers forms the standard section size. $\endgroup$– Forward EdMay 10, 2021 at 2:27
1 Answer
It's a truss bridge.
A quick Google Image search will make the difference between the bridge types clear.
This is a plate girder bridge:
And this is a truss bridge:
Basically, a girder bridge uses a few massive longitudinal beams while a truss instead uses a criss-cross of smaller beams instead.
