I was watching a video that derives the forced vibration response of a beam. The link to the video is https://www.youtube.com/watch?v=6VuLZDgRhZ4&list=PLMXj6GKKnHI6Lftj7CXr9WusMkXi5s9yH&index=56
In the derivation, why is it correct to use the expressions for $w_n$ and $U_n$ (natural frequencies and mode shapes) that were derived based on free vibration of a beam?
These expressions were derived using the method of separation of variables by equating the first two terms in the equation of motion (EOM in the image above, with f equal to 0 for free vibration) and then equating them to a constant. The two separate equations, one that depends on time and another that depends on position, are set equal to 0 and boundary conditions are used to find the natural frequencies and mode shapes.
But why is valid to perform these steps when the right side of the EOM is not zero?
  • $\begingroup$ The idea is to use something called "linear superposition" which applies for systems that experience infinitesimal strains and small displacements. You can then compute the effect of a force boundary condition but just adding it to a solution ("modal superposition") without any forces. $\endgroup$ Apr 24, 2021 at 20:40
If I get your question correctly what you are asking essentially is, why are we using the formulas for the free vibration to predict the forced behaviour.
TL;DR: The general case of the forced excitation can be modelled as many cases of constant forces acting on a very small time interval
Impulsive excitation
I will start from this because its the basis for what follows. Basically, if you have an impulsive excitation you have a force, that acts for a very small time. The impulse $I$ is then $I= F\cdot \Delta t$, where F is the force (assumed constant) and $\Delta t$ is the time duration that the force acts.
So, on first glance, you could say that the equation of motion is:
$$ \ddot{x}+ 2\zeta\omega_n\dot{x}+\omega_n^2 x = \frac{F(t)}{m_{eq}} $$
However, if you think about it after the force stops acting, then essentially you have a free vibration. So, if the $\Delta t$ is sufficiently small and you know the velocity before, then you can obtain the velocity just after the force stopped acting, through the principle of impulse momentum. Assuming the mass was initally at rest (to simplify the example), the velocity of the mass ($v_0$)just after the force stopped acting will be:
$$ v_0 = \frac{I}{m}$$
So now, you have a problem, with no forced (thus a free vibration) with non zero initial conditions. So the forced problem devolves to a problem of free vibration with initial conditions.
$$ \ddot{x}+ 2\zeta\omega_n\dot{x}+\omega_n^2 x = 0 , \text{ with } x(0)=0, \;\;\dot{x}=\frac{I}{m_{eq}} $$
General Excitation
If you get the general case of the forced excitation it may look like
However that can be partitioned wrt to time to look like the following image. In that case the force can be thought as constant (if not, then you can take a much smaller interval)
Now the area on each of those intervals is $\int F\cdot dt$, therefore its impulse of the force $F_i$
Putting things together
So now, what you can do, is take a general excitation (any in fact), break it up into smaller pieces. Then for each piece calculate the impulse, and then the response x(t) as a free vibration with initial conditions. Finally you take all the responses and stitch them together.
The stitching part is not exactly what you'd call a walk in the park. It is actually called "Convolution integral/Duhamel integral", and unfortunately is beyond my capacity to explain in a way that its comprehensive in this forum, but if you are interested you can read about it.
