I'm studying "signals and systems". We can indentify two kinds of signals: power signal and energy signal.
The definitions are:
Energy of a time-continous signal $$ E_x = \int_{-\infty}^{+\infty}{|x(t)|}^2dt $$
Power of a time-continous signal $$ P_x = \lim_{Z\rightarrow+\infty}{\frac{1}{2Z}\int_{-Z}^{+Z}{|x(t)|}^2dt}$$
An energy signal satisfies $0<E_x<+\infty$ and $P_x=0$.
A power signal satisfies $0<P_x<+\infty$ and $E_x = +\infty$.
Now, if we have a signum function
$$sgn(t)=\left\{\begin{matrix} 1 & if\;t \ge 0 \\ -1 & if\;t < 0 \end{matrix}\right.$$
and we calculate the formulas, then we obtain:
$$P_x = 0 \;\; E_x=0 $$
My question is, as the title said: the signum function which kind of signal is?
    $\begingroup$ signum is hardly time continuous. (massive jump at t = 0) $\endgroup$ Sep 3, 2015 at 10:01
    $\begingroup$ Also the vertical bars indicate absolute amplitude which is a constant 1 which makes $E_{sgn} = +\infty$ and $P_{sgn} = 1$ $\endgroup$ Sep 3, 2015 at 10:50
  • $\begingroup$ Correct! I forgot the absolute value! Thank you for answering anyway to my stupid question! I will pay more attention next time. $\endgroup$
    – GenKs
    Sep 3, 2015 at 11:02
  • $\begingroup$ @ratchetfreak That function is time continuous. That means there are no discontinuities in time. $\endgroup$ Feb 6, 2017 at 0:50
First point is that signum is not continuous with the jump at $t=0$.
Second because of the absolute value in the integral it has the same $E$ and $P$ as a constant signal $1$.
This means that $E_{sgn}=+\infty$ and $P_{sgn}=1$
  • $\begingroup$ No one said that the function is continuous. It was claimed that the signal is time continuous, which it is. If you change that, I would upvote since it is otherwise a correct answer. en.wikipedia.org/wiki/Continuous_signal $\endgroup$ Feb 6, 2017 at 0:52
