We have conducted tensile testing after casting HPDC (using test specimen from casted parts), to check the elongation. Results are not same for most of the location, due to the different thickness and geometry of teh parts.
what type of best practice will be used in industry for casting parts to check the mechanical properties ?
Materiel AlSi10MnMg
  • $\begingroup$ Could you provide more information regarding the actual values and the materials used? Also, if you could rephrase the question, to make it more understandable, it might be easier to obtain a helpful answer. $\endgroup$
    – NMech
    Apr 19, 2021 at 8:48
  • $\begingroup$ I have updated now, is it clear now? $\endgroup$ Apr 19, 2021 at 9:26
  • $\begingroup$ It is definitely better (still there some issues: e.g. but results are not met the required value. As I mentioned before, it will be easier if you provide a bit more detail about your setup. E.g. What material are you using. What are the properties you got? What were the properties you were expecting? Maybe give a rough sketch on the die casting dimensions and/or your test specimen... $\endgroup$
    – NMech
    Apr 19, 2021 at 9:31
  • $\begingroup$ Restating the other comments : Helpful suggestions could be made if any specific information was presented; alloy, tests, results, requirements, size or volume of parts, etc. $\endgroup$ May 20, 2021 at 14:25
  • $\begingroup$ Did the cast follow any standard regarding chemical composition and process, and where was the "comparing value" came from? $\endgroup$
    – r13
    Jun 18, 2021 at 21:03
3 Answers 3
Your question is a bit hard to understand; my thought is you must now discover the source of the low values so that the quality of your castings can be improved to meet the specification.
To do this, you will need to inspect and examine the microstructure of the failed parts where they broke in the testing machine.
Because the test coupons cut from the part did not meet specification , the parts do not meet specification. Very generally , for materials other than steel ,the failure implies the chemistry is wrong. For steels ,you should consider a heat-treatment. Depending on material , the mold "shake-out" temperature can affect physical properties. For many specifications using test coupons cast separately from the parts is illegal. There are chapters in quality assurance books to prevent a manufacturer from doing something "creative " with test coupons to pass a test when the product will not pass the test.
  • $\begingroup$ At the extreme , this question is asking how to falsify test results. $\endgroup$ May 19, 2021 at 15:15
To quantify properties of parts (cast or otherwise) one may need to design a test specific to the part. Usual questions answered by this tend to be along the lines of: "Will my part be able to handle what it needs to?" The amount of testing is usually narrowed down via a theoretical model. For example one might attach strain gages at specific locations based on a model and subject the part to loads gathering information to support the model. Other tests may include laser vibrometry, cyclic loading and testing to failure. It all depends on the function of the part, and will likely involve multiple tests and statistics to prove that the results apply to similar parts made via your process. When in doubt, the test becomes use of the part as it is meant to be used, for the life of the part while measuring for what constitutes failure of the part to perform its function. The need for enough historical data to be able to narrow down required testing for each part variant can make entry into industry difficult; standardized parts are a summarization of such results intended to make it easier to produce specific parts.
To quantify properties of a cast material, one casts (and then machines) to standard material testing shapes. Testing the specimens then goes toward generating material properties. Continuing to generate and test them with batches of parts produced can support (along with additional statistical data proving correlations) the claim that material used in one batch is similar to that used in another. The results can be used to model properties of a part, but such models then need to be validated.
There are also cases where a standardized specimen can be machined out of a specific locations on a part. Specimens (and test results) are categorized by these specific locations since the conditions in the manufacturing process can vary by location. The results provide support to models of the process that made the specimens and can often be applied to infer properties at other locations on the part (helping model the part), contributing to quantifying both material and part properties.
Ultimately it comes down to mathematical models, test results that support those models, and people with enough knowledge to design models to accurately correspond to reality and tests to cover your part's function.
