Im working on a project that has gearing system integrated. From my simulation results im dealing with a relatively small amount of input force at the gearbox and would like to know if the force would be transmitted through the gears which i chose at all. I cant seem to find any consistent or not so complicated information about how to calculate the static friction to overcome before motion. Can anyone point me in the right direction? A simplified estimate or model will do. I would like information on spur and bevel gears. Thanks
Edit. I added a pic as per request. enter image description here
  • $\begingroup$ You need to provide a sketch showing how the gears are intergrated, the force, and indicating the friction on which part is in interest. $\endgroup$
    – r13
    Apr 18 at 21:26
  • $\begingroup$ Including the friction from the bearings? $\endgroup$
    Apr 18 at 22:09
  • $\begingroup$ I added a pic. my forces calculations are not finalized so a formula would suffice. As for friction, all the gears in mesh and yes the bearings. Thanks $\endgroup$
    – Tony
    Apr 18 at 23:02
Theoretically, a well lubricated, aligned, and maintaned gear box should have theoretically zero static friction. If you are after estimating what the torque is to get it to move, to my experience, it is always easier and best to test the torque required to start it moving.
The reason is that apart from the individual elements, how you implement and setup the gear box can have a detrimental effect. I'll count some of the sources that can really throw off your calculations:
  • poor alignment of the geometrical axis of the shaft with the axis that the center of the bearings form.
  • tightening too much (or too little) a fastener on the system
  • dimensional variations within the acceptable tolerances
  • temperature setting
  • condition of the gear box.
In the theoretical best case scenario, you'd have
  • spur gears almost zero losses
  • helical gears (due to the axial force component that is generated) you'd have higher losses (depending on the angle of the teeth)
  • bevel gears: even higher losses
Bottom line is that you'd have a better chance with a design that uses spur gears. You should spend some time designing and finetuning the assembly, and then actually measure the torque required to get it to move.
A final note, is that if acceleration is important, then you should also take into account the moment of inertia of the rotating parts (that will have a significant impact on the starting torque).
  • $\begingroup$ Thanks. Ill just follow best practices and hope for a low torque. On what you said about moment of inertia, does it affect starting or acceleration torque? $\endgroup$
    – Tony
    Apr 19 at 12:19
  • $\begingroup$ Basically, the angular acceleration is $a = \frac{M}{I} $, where M is the excess torque (Total Torque - starting Torque) , and $I$, the moment of Inertia. The more Torque, the more angular acceleration. $\endgroup$
    – NMech
    Apr 19 at 12:22
The friction of a gear train is dependent on many factors. From viscosity of the gear box lubricant to gear size and ratio, geometry of gears, rolling friction, sliding friction; tens of other factors. bearing friction, the stifness of the shafts, angular momentum of the gears and the the stiffness of the box containg the gears are some other factors.
As a rough starting piont the average friction losd in a car is 35% of the engine output. much of it is due to rolling friction of the tires, air resistance, friction in moving parts of the power train. A rough estimate of 10 to 15 percent is friction loss in the transmission.
There are torque brakes and strain guages that can measure the friction loss. For exact measurements they use laser interferometers too to measure the backlash of individual gears and behavior of the lubricant.
  • $\begingroup$ you gave estimates on efficiency. What about say considering only dry friction i want to estimate a force required to move only 2 spur gears in mesh. It is for an energy regeneration project. $\endgroup$
    – Tony
    Apr 19 at 7:47
As others have pointed out there are many other factors that affect the net efficiency of a gear mesh, but a good rule of thumb is that any decent spur gearbox is 95% efficient at each mesh. Approximate gear efficiencies by type
