Is a concrete screw like the HILTI HUS3 removable?
I.e. can it be repeatedly unscrewed and reinstalled as required? Will this damage the fixing or the hole in the concrete?
We're thinking about using it for a bund that occasionally will need to be removed for access.
    $\begingroup$ Use screw/bolt with embed socket. $\endgroup$
    – r13
    Apr 8, 2021 at 10:45
No, they are usually fitted once and left.
If you need to remove them then you need to drill new holes.
Or you should consider fitting a wooden framework to the concrete and attaching to that so it can be easily removed and refitted, without disturbing the concrete fixings.
