Using a laser to cut sections out of a small moving solid has been suggested for a manufacturing problem. However, usually lasers come as a point, which means that we'd have to make the laser head move in quite an exotic curve, which will slow down our cut rate.
Is there a known solution to this? In my head, if the beam was instead focused as a blade and not as a point this would solve this, but I'm unable to find any existing solutions.
Ideally we don't want to move the laser head, or move it as little as possible to get our number of cuts per second as high as possible.
The limiting factor is usually the cutting speed of the laser. This depends on the laser power, the material characteristics (if it even can be cut by laser) and the material thickness. The fact that you have an exotic curve doesn't really enter into it much unless the motion can't keep up. In fact an exotic curve should be quicker to cut than a load of straight lines with sharp corners as the motion needs to decelerate to a stop in each corner.
If it's "focused as a blade" then the energy density will drop and cutting time will increase.
Figure 1. Flying optics. Image source: Smoke and Mirrors.
You have two options that I know of:
  • Flying optics. The laser stays put and the mirrors move around on an X-Y motion.
  • Galvanometer mirror deflection but this will result in angled cuts if your material is thick.
  • $\begingroup$ Flying optics is what I've seen for lower power production machines (work stays still, to be clear). With a part on a conveyor, adapting this to track 1axis motion essentially, this would be the way to go IMO. $\endgroup$
    – Pete W
    Mar 26, 2021 at 17:09
  • $\begingroup$ Good answer. Small detail, angled cuts should not be a problem with galvo scanners, they are usually used with a special lens that lets the laser hit the work piece straight from above. $\endgroup$ Mar 26, 2021 at 17:47
