I have the code below:
;Start of Script 1
;command
-pdfimport
;leave empty to select file
f
;file location
"C:\Users\Lenovo\Desktop\Electrical Department\samplepdfonly.pdf"
;pagenumber of pdf
;specify insert
0,0
;scale factor
;rotation
;End of script 1
;Start of Script 2
;command
-pdfimport
f
;file location
;pagenumber of pdf
8
;specify insert
800,0
;scale factor
;rotation
;End of script 2
;Start of Script 3
;command
-pdfimport
f
;file location
;pagenumber of pdf
9
;specify insert
1600,0
;scale factor
;rotation
;End of script 3
And I'm trying to make this part, automatically adjust by adding an incremental variable of +800
;specify insert
0,0
For example, it will then becomes
;specify insert
800,0
then
;specify insert
1600,0
Is it possible?
In programming it is something like
Var X as integer = 0
Then
;specify insert
x+800
x,0
