The following is a picture of a locking pin for a tubular hinge which specifies Maritime use. I assume it has something to do with railings but I'm thinking of fabricating my own similar hinges. "Locking pin" seems awfully vague. I know I've seen this before; the little nub at the end is spring loaded and presses into the pin
    $\begingroup$ Go to an agricultural machinery supplier - they have many... $\endgroup$
    Commented Mar 25, 2021 at 14:09
  • 4
    $\begingroup$ a retaining pin, generally. "ring pin", or "ring pin with detent" should get good search results $\endgroup$
    – Pete W
    Commented Mar 25, 2021 at 14:26
  • $\begingroup$ This is also sometimes colloquially called a cotter pin, hitch pin, clevis pin or even pivot pin. But I kind of doubt you'll find it on a parts list under those names. $\endgroup$ Commented Mar 25, 2021 at 23:13
    $\begingroup$ A cotter pin is made from bent wire, that's pretty distinct IMO $\endgroup$
    – Pete W
    Commented Mar 26, 2021 at 3:54
  • $\begingroup$ The answer by @jko got it specifically -- one other name commonly used for this and similar shapes is a "pip pin" $\endgroup$
    – Tristan
    Commented Mar 26, 2021 at 16:27
13
That is a ring-grip quick-release pin, sometimes referred to as clevis pins. McMaster link
  • $\begingroup$ Yes! That's what I was looking for. Even a Google reverse photo search didn't find an answer. $\endgroup$
    – Walter
    Commented Mar 25, 2021 at 22:50
    $\begingroup$ McMaster >>> Google $\endgroup$
    – jko
    Commented Mar 26, 2021 at 11:39
