I have problem where I'm trying to determine the Overall Heat Transfer coefficient of a heat exchanger that uses the latent heat of vaporization of water in the process.
I know the Q value I'm trying to get to, the heat transfer area, and the temperature differences.
I'm aware the standard equations being used here would be
Q = UAT and Q = mcpT
for a normal heat exchanger, but I'm not sure how that works alongside vaporization.
Any help would be greatly appreciated - thank you.
  • $\begingroup$ Power in upstream compared to power out downstream for a given set if conditions is one starting point. $\endgroup$
    Mar 26 at 5:47
