Help out a college student.
How do you derive the deflection equation y(x) of the shown stepped cantilever beam in the figure? Each segment has a unique Young's modulus and moment of inertia. The thickness of segment 1 is larger than segment 2. I will be needing the deflection equation to derive the resonant frequency of the beam using Rayleigh method shown:
$$ \omega^2 = \frac{\int_{0}^{L} EI \left( \frac{d^2y(x)}{dx^2} \right)^2 \,dx}{\int_{0}^{L} \rho A (y(x))^2 \,dx} $$
where L = L1 + L2
I have tried using the deflection equation of a uniform cantilever beam with concentrated load F at the free end $y(x) = \frac{Fx^2}{6EI}(3L-x)$, but when I substitute this equation to Rayleigh equation and compare the resonant frequency values to COMSOL (FEA) simulation results, it does not follow the trend of resonant frequencies obtained when I try to vary the length of segment 1. However, it does follow trend of resonant frequencies when the width and thickness of segment 1 is varied.
I hope you can give me some advice. Thanks!
