This one is gonna be hard for me to explain, but I hope you will get it
I have this sketch: part
Each side of this part is half of it, to be easily duplicate / mirror / pattern Important to note the both ends of this chain needs to be just the half (so in IRL can be connected to a round object and glued together) This is how a full part looks (made from two half's) (sorry for the mass, mirroring it cause all this chaos): joined part
And I want to duplicate 40~ times it to this shape that I created:
spiral
The reason for it to be a spiral and not a a round circle is so save space on the mold
some guidelines and restrictions:
  1. each hinge need to be between 185-195 degrees, preferably as little as much variations (although necessary to achieve the spiral)
  2. Need to retain the ability to change the length (125mm here) , width (17mm) and number of parts
  3. ends need to be the half shaped
  4. if you have another way that is more efficient then manually doing the spiral it will be amazing
Really hope that its clear enough, appreciate your help, thanks
  • $\begingroup$ You need to use sketch blocks for something like this. $\endgroup$ Commented Mar 17, 2021 at 11:36
  • $\begingroup$ Can just import the block and set it to be parallel to each line and coincident where relevant. $\endgroup$ Commented Mar 17, 2021 at 11:38
  • $\begingroup$ The master strikes again! Thanks, I thought about it, but its highly manual and not modular, I thought that maybe there is a better faster way $\endgroup$
    – Simon
    Commented Mar 17, 2021 at 11:41
  • $\begingroup$ Not sure - could experiment with curve driven pattern etc, but the alternating straight-bend-straight of your specific application makes me not sure it would work $\endgroup$ Commented Mar 17, 2021 at 12:02
