The usual woodworker/house builder rule of thumb is to place the top hinge 6" (150 mm) from the top of the door, and the bottom one 9" (228 mm) from the bottom - the common reason for this is illusion of "foreshortening" and this results in a visual balance of the hinges on the door. If a 3rd hinge is used, it is placed halfway between the top and bottom hinges.
In modern office buildings it is common to see a hinge spacing that doesn't follow the usual rule.
What is the reason for this arrangement of hinges?
