I am securing a cantilever umbrella baseplate to a deck. The decking timber will be reinforced with a pine nog between the deck joists.
The options that I have are to use 10mm stainless steel coach screw that will be embedded into a 70mm nog.
Alternatively I can use a 10mm bolt, washer and nylock nut that will be secured through a 50mm nog.
The timber will be the same grade wet H5 pine. The deck plate is the same size and thickness, as is the material of the screw / bolt.
Which method will be stronger. I can't use a longer bolt due to the limitation of space under the decking timber in order to fit the nut.
Thanks
  • $\begingroup$ Perhaps a plate to spread the load rather than a washer under the nog? $\endgroup$ – Jonathan R Swift Mar 5 at 7:55
  • $\begingroup$ can you provide a sketch of what you plan to do? $\endgroup$ – mart Mar 5 at 9:33
