I am using Matlab to plot contour of the cam. So far, I understand how to use angular displacement relation between cam and follower to get the profile, pressure angle, torques etc. What I aim to do is go backwards; for a given torque vs rotation of the cam getting the profile and angle relations. How should I approach this problem?
edit1: The cam is loaded with a torsion spring that produces torque. I am considering static cases at different angles so time is not considered
  • $\begingroup$ How about the time and lift or opening or movement required ie rate of position change. $\endgroup$ – Solar Mike Feb 25 at 17:25
  • $\begingroup$ @SolarMike The cam is loaded with a torsion spring that produces torque. I am considering static cases at different angles so time is not considered. $\endgroup$ – Mridul Feb 25 at 17:33
    $\begingroup$ Doesn't that information belong in the question? Don't bury it in the comments. $\endgroup$ – Transistor Feb 25 at 17:47
