I was reading: https://www.tec-science.com/mechanical-power-transmission/involute-gear/geometry-of-involute-gears/
Which goes over construction of involute gears, Everything else makes sense but I am still confused on what defines the tooth width.
Does someone have an intuitive/easy explanation on how you derive the tooth width for an involute gear and why it makes sense?
