Given:
  • A pump system is defined with dynamic head of 46 feet.
  • The height between the static pressure gauge and the surface of the water is 9 feet.
Assumptions:
  • Friction losses between the tank and pump are approximately 0.
Hint:
  • The pressure gauge is capable of sensing static head, but not velocity head.
Find:
  • The velocity of the water through the pipe.
Work:
Use Bernoulli's equation, solve for V2.
$\dfrac{P_1 * g_c}{\rho g} + \dfrac{v_1^2}{2 g} + Z_1 = \dfrac{P_2 * g_c}{\rho g} + \dfrac{v_2^2}{2 g} + Z_2 + H_A$
Rearrange to solve for V2. $v_2 = [(\dfrac{(P1 - P2)g_c}{\rho g} + Z_1 - Z_2 - H_A)2 g]^{1/2}$
Point 1 is defined at surface of water...
$ v_1(@P_1) = 0 ft/sec, Z_1(@P_1) = 9 ft, P_1(@P_1) = 0 PSIG.$
Point 2 is defined at static pressure gauge...
$ P_2(@P_2) = 23 PSIG, Z_2(@P_2) = 0 ft.$
$v_2 = [(\dfrac{(P1 - P2)g_c}{\rho g} + Z_1 - H_A)2 g]^{1/2}$
Should the dynamic head $H_A$ be added or subtracted here?
  • $\begingroup$ Thanks, I modified the question. This is not a homework problem. It is a diagnostic test problem for the ME PE exam. $\endgroup$ – Jason Feb 23 at 19:22
