I am generating a very simple DXF file with the netDXF library. The DXF is a polyine box with text in the middle. When I open the file in SpinFire and DWG Trueview the text is centered (image with H aligned center). However, when I open it in eDrawings the text is way off (image with H off center).
Does anyone know what could cause this? I wonder if I am missing something in the header or what could cause these viewers to show the same file differently. My best guess is that eDrawings does not respect the alignment property. Any insight is greatly appreciated. SpinFire eDrawings
    $\begingroup$ Please add screenshots? And perhaps even some link to the file if it's not confidential $\endgroup$ Feb 22 at 13:41
  • $\begingroup$ Thanks Jonathan I added screenshots. $\endgroup$
    – GeersJ
    Feb 22 at 16:02
This seems to be just a quirk of eDrawings where it prefers the MText object. Discussion here.
