So I'm not actually an engineer, I'm a novice computer programmer but I think in order to solve a problem I have I'm going to need some help from the world of engineering.
I remember in high school they were teaching a civil engineering calculus class and one thing they spent a lot of time on was how to figure out the perfect curve for the perfect slope to transition the road to a bridge smoothly. My computer program is a digital paint and photo software which may include 3D sculpting and modeling later on. There is an existing tool that I don't know a ton about but it does something kind of similar called a Bézier curve and basically, it lets you find smooth curves. But I'm looking for something else as well, I think.
Here's a rough picture of what I'm trying to do. Imagine this is someone's face. It is showing a mid-tone and a shadow. The green circle is where an AI-powered healing stamp will attempt to conceal a blemish. But there's a problem. There's both shadow and midtone in the same area as the stamp, and we're basically inventing contours in the skin. The robotic way to do it would be to just B-line between both instances of shadow, but maybe it would look more organic if there was a smooth transition between the external shadow's slope going in and the artificial shadow that continues.
So, what math would you use to figure that out, and does anybody know of any good place to learn it? Could I do it with just Calculus I under my belt?
A diagram showing an abstracted part of a face in two examples, one where the shadow is cutting across the healing stamp's surface linearly, the other where a smooth curve is connecting them.
I think you are referring to ‘vertical curves’ for the slope transition of roadway to bridge. Also known as parabolas.
The graphic transition can be accomplished with a spline. Bezier is a spline. See Wiki: Spline
  • $\begingroup$ Thanks. I've known about Bezier for a long while and no one ever said it was a spline. That might be what I end up using. Parabolas also seem like a good way to make a smooth transition. $\endgroup$
    – Ikari
    Commented Mar 2, 2021 at 5:55
I don't know about image editing but for the roads and railroad track transition from a straight path to a rurn there is a transition called "Spiral Easement".
basically, it gradually eases into the turn and it is a 3-dimensional curve starting from a flat straight path gradually joining the turn with the transversal pitch required to make the turns safer.
if you look at its plan only, it looks like a spiral traced with a rotating generator gradually getting smaller and curving more.
Amimatiom figure.
Here is the Wikipedia link. link.
  • $\begingroup$ always a trove of knowledge $\endgroup$
    – NMech
    Commented Feb 21, 2021 at 8:05
    $\begingroup$ In highways, in Canada at least, Clothoid Spirals are used to transition from tangent segments to circular segments in the horizontal plane. The vertical plane is usually parabolas. $\endgroup$
    – Forward Ed
    Commented Feb 24, 2021 at 20:27
  • $\begingroup$ The road design software I used had 5 different horizontal curve choices for transitions: different road organizations used different curves. I don't know if there were choices for the vertical plan. $\endgroup$
    – david
    Commented Jul 12, 2023 at 22:59
