Open channel flow in a circular pipe has a maximum flow $Q_{max}$ at a flow depth approximately 93.8% of the pipe diameter. Calculating flow Q from depths 92.5% and 94.9% both give the same value for Q.
So, if we know that the flow is Q, or if we are designing for a flow of Q, how do we determine which flow depth be correct in practice?
