I have an object that weighs approximately 10 grams = 0.022 pounds. I know it can hold at least 45.1 pounds without breaking. It's a cube-like object so I placed many books on top of it and weighed the books.
I want to compare the strength of the object to steel to see how strong the object is.
How do I calculate the strength to weight ratio of this object?
I think it can hold 2,050 times its weight based on 45.1/.022=2,050.
I read that megapascal's (MPa) are used to assess how much force an object can withstand.
A megapascal (MPa) is a metric pressure unit, mostly used in hydraulic systems that gauge high pressure ratings, that equals 1,000,000 newtons per square meter (which is a pascal). 1 MPa is equal to 10 Bar.
  • 4
    $\begingroup$ If you drive a 30 ton truck over a piece of paper, the weight of the truck doesn't "break" the paper. What is the real question you are trying to ask? $\endgroup$ – alephzero Feb 10 at 16:15
  • $\begingroup$ I meant to say "cube"-like object. It's 3 dimensional $\endgroup$ – geocalc33 Feb 10 at 18:45
  • $\begingroup$ I think this would be a valid question if you rephrased it. Something like "how do I calculate the strength to weight ratio of this object" (along with more details about the object and force applied to it). $\endgroup$ – Drew Feb 12 at 8:37
