I'm not having luck with the Trim Entities feature, which is just for sketches. I just want to shave the top part off completely at the angle that I've drawn. enter image description here
    $\begingroup$ Make your angle into a plane along face you want to cut, then you can use it to trim or cut. $\endgroup$ Feb 1, 2021 at 17:29
  • $\begingroup$ @StainlessSteelRat thank you! that worked (with insert > cut > with surface) $\endgroup$
    – Mohanachz
    Feb 1, 2021 at 19:47
  • $\begingroup$ In Solidworks, there are many ways to do things. $\endgroup$ Feb 1, 2021 at 20:00
  • $\begingroup$ @Mohanachz - if "that worked" how come still no answer is marked correct? 😅 $\endgroup$ Feb 4, 2021 at 18:46
  • $\begingroup$ @JonathanRSwift oops sorry, fixed $\endgroup$
    – Mohanachz
    Feb 5, 2021 at 19:41
There's a couple of ways to do this - I've illustrated both @StainlessSteelRat's Plane Cut method, and @NMech's Cut/Extrude method.
Both are valid, and as always with these questions - there's not enough context to recommend which of these two, or the numerous other potential methods is best for your situation.
  • Just create a sketch on that face.
  • Then draw a box that includes completely the part you want to get rid off.
  • Use that sketch with a cut extrude feature.
