given that handy stroboscope can also check translational vibration of parts, is it a substitute for a test that can be done by accelerometer for stationary vibrating equipment?
    $\begingroup$ This is pretty much a repeat of your previous question, engineering.stackexchange.com/questions/40018/…. If you don't get an answer to a question then please improve it rather than post it again. $\endgroup$ – Transistor Jan 29 at 16:29
  • $\begingroup$ No it's not a repeat, that was with focus on vibration type here the instrumentation is the focus $\endgroup$ – FabioSpaghetti Jan 29 at 18:19
No. Strobes are useful for what they can do, but they are not substitutes for accelerometers.
A strobe can give you a "picture", but it doesn't measure anything except maybe frequency. It doesn't measure amplitude, harmonic content of the vibration, etc.
Also a strobe is only useful for amplitudes which are big enough to see. Accelerometers can measure high frequency vibrations with amplitudes of micrometers or smaller.
