I have a glass here.enter image description here
This is the bottom face of the glass. enter image description here
Now this is on what I had kept my glass. There is a little much of water spilled on it. Let us call this thing as C
Now , when I lifted the cup. The C on which I had kept my glass also lifted up. The bottom portion of glass and the top portion of the thing were in contact. They did not leave each other.
Now , the bottom portion of the cup is flat. So, I kept my glass on that C. The cup and the C both lifted up. Why is it like that ? They should not do this.
The surface of C where the glass sat is smooth, then the glass may have a slightly concave bottom and the water, with capillary action, managed to form a seal between the two surfaces. Even if the glass bottom and surface C are both flat, capillary action can still form a seal around the edge leaving a void in the centre, causing the same effect of lower v. higher pressure.
If the air trapped in there then cools down a few degrees - the outside air pressure holds the two items together. Until of course mass or vibration takes over and the item C falls off.
Happens often with coasters and glasses.
A hot cup of tea can show bubbles when there is some spilt tea in the saucer - the trapped air is being heated, until the tea in the cup cools and we have the same situation as above.
  • $\begingroup$ Is it like pressure inside the seal is lesser than pressure outside (i.e air). $\endgroup$
    – S.M.T
    Commented Jan 29, 2021 at 7:21
  • $\begingroup$ @user15072279 that's why I mentioned the temperature change in my answer.... $\endgroup$
    Commented Jan 29, 2021 at 7:23
  • $\begingroup$ @user15072279, and the force produced will be $ \Delta P \times A $ (the difference in pressure between the cavity and atmospheric times the area). $\endgroup$
    – Transistor
    Commented Jan 29, 2021 at 7:28
  • $\begingroup$ This may be overcomplicating things - two smooth surfaces with water to fill any gaps can stick together just from electrostatic attraction $\endgroup$ Commented Jan 29, 2021 at 13:19
