this is a part of my parameter study for the experiment (a vibration analysis with a force impulse input). This specific part studies the frequency resolution effect on the spectrum. The input (i.e.: impulse force) enter image description here
My main question is: why increasing frequency resolution (or frequency bin) would lead to the disappearances of sudden peaks at 50 and 150 Hz?
Note that the original input signal is the same, the only thing changed is the number of FFT lines (also known as spectral lines) and via that the frequency resolution.
Edit: Upload for measurement set-up enter image description here
Edit 2: Sampled point format enter image description here
Sampled point format, from 0 to 170 Hz (zoom in) enter image description here
  • $\begingroup$ Comments are not for extended discussion; this conversation has been moved to chat. $\endgroup$ – Wasabi Jan 25 at 23:55
