I'm trying to create higher resolution data with a beam angle of 5> degrees (as close as 1 degree as possible). I have been experimenting with creating using an aluminum casing around the sensor input. Are there any other or perhaps better ways of doing this?
CH201 datasheet.
Consider something like the following. Use 3D printer to experiment.
Reference:
  • $\begingroup$ That image is for a 45" beam profile. The OP is requesting less than 5 degrees. $\endgroup$
    – Eric S
    Commented Jan 17, 2021 at 16:50
  • $\begingroup$ @EricS You are correct, I am providing OP an idea, to achieve 5 degree's. Currently OP is using an aluminum casing. $\endgroup$ Commented Jan 17, 2021 at 18:31
The datasheet, page 11, says:
CH201 Beam Patterns
The acoustic Field of View is easily customizable for the CH201 and is achieved by adding an acoustic housing to the transceiver that is profiled to realize the desired beam pattern. Symmetric, asymmetric, and omnidirectional (180° FoV) beam patterns are realizable.
An example beam pattern is shown in the Typical Operating Characteristics section of this document and several acoustic housing designs for various FoV’s are available from Chirp.
Talk to them!
  • $\begingroup$ Some sort of link would help this answer. $\endgroup$
    – Eric S
    Commented Jan 16, 2021 at 23:22
    $\begingroup$ The OP has the link buried in the comments. $\endgroup$
    – Transistor
    Commented Jan 16, 2021 at 23:39
  • $\begingroup$ Please put it in your answer. You shouldn’t make people search for important information. $\endgroup$
    – Eric S
    Commented Jan 17, 2021 at 16:02
  • $\begingroup$ I put it in the question where it should have been. Thanks. $\endgroup$
    – Transistor
    Commented Jan 17, 2021 at 16:22
  • $\begingroup$ I still think it is best embedded in your answer since you are referring it. You might think it is redundant, but why make the reader search? $\endgroup$
    – Eric S
    Commented Jan 17, 2021 at 16:48
