A drum is subjected to a counterclockwise torque of 16 in-lb. What horizontal force is necessary to resist motion?
Coefficient of friction = 0.40
Weight is neglected.
Figure 9-45 of Schaum's outline of engineering statics and dynamics
I'm having a hard time on this one. I've tried to separate the torque into a normal and tangential force and do a summation of moments at B and even at A. No luck. Though I doubt that's how it should be tackled.
Edit (my trials/errors):
I've read a pdf on brakes and learned that there are so many types and equations to accommodate each one. The closest I've seen to the one above was that of a single block brake; with 3 variations on the position of the line of action (the tangential force), $f$, passing through, above, or below the fulcrum.
![An example of a brake system, with the tangential force below the fulcrum] (https://i.stack.imgur.com/xtKAl.jpg)
It doesn't look the same, but the proof in this was the one I used. That being:
$$T_b \text{ (Braking torque)} = f \text{ (tangential force)} \times r \text{ (radius of wheel/drum)}$$
And the old
$$f = \mu \text{ (coefficient of friction)} \times N \text{ (normal force)}$$
I think my mistake was that I used the 16 in-lb torque as the braking torque ($T_b$) and went on from there.
$$\begin{align} T_b &= fr \\ \therefore f &= \dfrac{T_b}{r} \\ f &= 16\text{ in-lb} / 8\text{ in} \\ f &= 2\text{ lb downward} \\ N &= \dfrac{f}{\mu} \\ N &= \dfrac{2}{0.40} \\ N &= 5\text{ lb leftward} \end{align}$$
And then a summation of moments at point B (counterclockwise positive), giving:
$$\begin{align} \sum M_B &= P(9) - N(9) + f(2) = 0 \\ \therefore 9P &= 5(9) - 2(2) \\ P &= 4.5556lb \end{align}$$
I also considered the pinned support reaction at A, which gave off another incorrect answer.
The correct answer is given: $P = 3.43\text{ lb}$
  • $\begingroup$ So, show your working so far. $\endgroup$ – Solar Mike Jan 14 at 16:04
