I am looking to add a condenser for a plant preserving container. The plants need water and I was wondering if I can have a passive method to condense atmospheric moisture to water. My container is small and I would like the condenser to be as small as 30 cm$^3$ (but I can be flexible). Is there a current passive miniature air well (condenser)?
My container design can be changed to fit the condenser (so it is irrelevant). Therefore I would like to find a passive condenser that is small enough but enough to water a plant continuously.
(note: I am not asking for a product, I am asking for a mechanism or a technology or a method)
  • $\begingroup$ Seeking product or vendor recommendations will get your question closed so I suggest that you edit to fix that. Why can you not seal the container to make a closed recycling environment? $\endgroup$
    – Transistor
    Jan 11, 2021 at 21:56
  • $\begingroup$ This looks like a resource-hunting question. Such questions are prone to becoming out-dated, and are therefore considered off-topic for this site. $\endgroup$
    – Wasabi
    Jan 11, 2021 at 22:15
  • $\begingroup$ I am asking for a technology or a method. I am asking if it is possible to design by myself. $\endgroup$ Jan 12, 2021 at 0:51
