I am trying to learn how to work out the bending moment for progressively complex systems to model a beam. I am assuming only one axis of motion (transverse = $y$).
For the basic equation of material elasticity, $σ$ represents stress and $ε$ represents strain in terms of longitudinal stretch of each segment of the beam resulting from transverse ($y$) displacement.
(1) Simple Spring
If you model the beam as a simple spring for which $E$ (Young's Modulus) is the spring constant and $I$ is the cross-sectional moment of inertia, according to this reference, you get an equation of material elasticity and bending moment, respectively, as:
$σ = Eε$
$M = EIy_{xx}$
According to Wikipedia though, it's the following, so I'm not sure about signs:
$M = -EIy_{xx}$
(2) Damped Spring
If you add a damper to the bar simulation, according to this reference, you get the following:
$σ= Eϵ-ηε_t$
$M=-EIy_{xx}-Iηy_{xxt}$
Question
I am having trouble understanding how to extrapolate these principles to increasingly complex beam models.
Three Element System:
For example, in a three element model you can have:
$σ + \frac{η}{E_2}\dot{σ} = E_1ε + \frac{η(E_1+E_2)}{E_2}\dot{ε}$
Four Element System:
Or in a four element model you might have:
$σ + (\frac{η_1}{E_1} + \frac{η_2}{E_2})\dot{σ} + \frac{η_1η_2}{E_1E_2}\ddot{σ} = (η_1+η_2)\dot{ε} + \frac{η_1η_2(E_1+E_2)}{E_1E_2}\ddot{ε}$
How would you similarly go about expressing the bending moment with these types of more complex models?
My Guess
From looking at the two known equations above, except for the signs which I don't know how to anticipate, it looks like the equation for the bending moment can be defined somewhat as follows.
Two Element System:
$σ= Eε-η\dot{ε}$
$M = -I(σ_{bend})$ (which roughly matches this ref)
$σ_{bend}= Eε_{bend}-η\dot{ε}_{bend}$
$ϵ_{bend} = y_{xx}$
If so then for the three element system we might have:
$σ_{bend} + \frac{η}{E_2}\dot{σ_{bend}} = E_1ε_{bend} + \frac{η(E_1+E_2)}{E_2}\dot{ε_{bend}}$
$M = E_1Iy_{xx} + I\frac{η(E_1+E_2)}{E_2}y_{xxt} - \frac{η}{E_2}\dot{M}$
Is this the right idea? What do you do with signs here? It seems like the signs don't match to the equations of motion in the two given examples so I'm not sure if there's something more to be done with them.
Thanks for any help.
