I need a mechanism with which one motor can drive one of two outputs. So only one output should be active at a time, but the mechanism should be able to switch between the outputs.
What is a mechanism like that called?
Sign up to join this communityI need a mechanism with which one motor can drive one of two outputs. So only one output should be active at a time, but the mechanism should be able to switch between the outputs.
Generically, one can consider this to be a transfer case. It's common in a four-wheel drive vehicle, although in such application, power is applied to rear only or front and rear. The concept is consistent, as a transfer case would provide the option to disengage power from one output and apply to the other.
In the process of researching this question, I discovered that there appears to be no commercial version in which one output is disengaged while the other is engaged. This doesn't change the concept behind the terminology.
Another side-branch of the research brought up power take-off units, which are similar in concept.
Even more generic is to consider your objective as a purpose specific gearbox.
Splitter boxes are widely available, but you have to build up your own clutch systems. They are most commonly used for hydraulics and other pumping applications.
All the hydraulic valves, manual, electric, automatic, remotely controlled even valves in a car automatic transmission, using pressurized oil or air, are a good answer.
A compressor coupled to an engine produces fluid pressure. This pressure is controlled by a valve. Depending on the position of the valve the pressure is disconnected from one task and diverted to a different task. Like a crane boom, going up or coming down.
