I´m designing an access control device and I need to place it in a plastic case so it can be easily installed on a wall, for example. Also, the PCB will have a special coating for humidity protection.
Regarding IP code grading for dust and water protection I would like to know:
If the device is on the outside without protection (roof or similar), would an IP54 plastic case be enough?
If the device is on the outside but it is protected with a roof or similar, would an IP54 plastic case be enough?
If this is not correct, what would be a right IP code grading for the case?
