What is the best way to attach skateboard wheels to an t-slotted framing? Also, is there a more economical way?
Bonus: How to design shock absorber for it?
  • $\begingroup$ make a bracket. design a bracket with hinge to add a shock absorber - such as a rubber pad. $\endgroup$
    Dec 28 '20 at 8:40
  • $\begingroup$ Most economical will be an M8 bolt with its head ground down to fit in the slot, washer(s) to space the week from the extrusion, and a Nylock nut to keep the wheel from falling off. $\endgroup$ Dec 28 '20 at 8:54
They have usually 7 inches wide trucks with 50mm diameter wheels pre-assembled with the shock absorber with 4-6 bolts going through the slotted opening. I show an example photo of Magnoto brand, I don't know them.
side view
top view
bottom truck
