I recently purchased a JGMaker Magic 3D printer. It worked well for about 3 months [first picture], but now it is having a lot of trouble.
As you can see in the images below, when printing new pieces, the pieces feel like they are made of cotton candy instead of solid plastic layers. I tried cleaning the tip of the metal printing nozzle, but this did not fix the issue. Maybe there is not a strong enough PLA filament stream extruding out of the nozzle? I’ve tried pushing PLA through the PLA tube to get the PLA to print out manually and it does work (there is PLA filament successfully extruding out of the nozzle).
What do you think is going on and what should I do to fix this problem?
Thank you for the help.
