I am simulating an air flow through a two dimensional rectangular channel. The channel splits into two channels, one of them is followed by a 90 degree bend downwards and leads into a cylindrical volume through which the air flows out of the geometry. Here is a picture of the geometry:
For the simulation I use the RANS approach with the k-omega SST model. However, the solution doesn't really converge. I located the problem in the area of the transition from the channel into the cylinder where the jet bends towards one side but doesn't completely stabilize there. Instead, it keeps flapping around which can be seen in an animation of a velocity contour over a few hundred of iterations: enter image description here
I assume that such a flow situation is indeed pretty unstable not only numerically but physically too. My question is the following: Given the transient nature of the flow shouldn't the RANS model just average out these fluctuations? Can a transient flow lead to instabilities in a steady RANS simulation? Do you know papers about this topic?
I would really appreciate your help!
  • $\begingroup$ What are your boundary conditions? what models are you using (compressible vs incompressible)? what kind of wall treatment are you using? what is the max $y^+$ have you achieved? There are so many reasons why a CFD solution does not converge, and you're not giving much information. $\endgroup$
    – Algo
    Dec 23 '20 at 12:41
  • $\begingroup$ I use a mass flow inlet and two pressure outlets, a compressible model and resolve the boundary layer with y+ < 1. I am pretty confident that the flow is transient in nature in this region. The question is wether this can be a reason for the convergence problems of a steady RANS simulation. $\endgroup$
    – Simon Henn
    Dec 23 '20 at 13:10
