I am actually working on making of a Stirling engine. I did some research work but most of the content on the internet is qualitative. So I am trying to build a small scale Stirling engine and trying to gather knowledge through trial and error way.
But since this is not my field of expertise so I thought to raise the question to the community first.
Suppose there is a Stirling engine whose Tcold is 0-degree Celsius and Thot is 200-degree Celsius. The piston is 35mm in diameter and the stroke is 24mm. The engine is made to run using air at a pressure of 2 bar.
Can anyone help me to determine the torque and rpm of this engine?
  • $\begingroup$ Perhaps because other tags are more than relevant. $\endgroup$
    Dec 20, 2020 at 15:03
It will be determined by the system load and internal friction factors.
Here's some initial thoughts on how to determien this:
Your power, $P$, is equal to the product of the torque, $\tau$ and your angular velocity, $\omega$,
$$ P = \tau \omega. $$
Assuming a completely adiabatic system, $$ \dot Q = P, $$ where $\dot Q$ is your heat in.
Therefore, you'd be able to write,
$$ \tau = \frac{\dot Q}{\omega}. $$
Now, what you need to know from your system is, $\omega = f(\tau)$. how much torque is required to produce a certain angular velocity. Once you know this, the intersection of the two curves give you your operating point.
  • $\begingroup$ one of the curve is w=f(torque) but what is the other curve? $\endgroup$
    – Tank
    Dec 22, 2020 at 6:12
  • $\begingroup$ It's the curve of the system. How much torque is required to produce a certain rotational velocity. This can be measured or derived through system modeling. It should be noted, this would only be for steady state analysis. Transient analysis is another matter. $\endgroup$ Dec 22, 2020 at 20:22
