I am filtering a signal, and want to check if I am not over filtering it , I wanted to use cross correlation , but I am not sure if it is a good technique. usually I get something like the following as Cross Correlation between the signal itself and the filtered one. i sit a good criteria?:
The filter is 4th order Bessel, lowpass filter, with 250Hz pass band for a 512Hz signal. no time lag between filtered and original
