I have to study the effect of low-pass filters (if any) on the outcome of the experiment. And the experiment here is to measure the vibration of a (metal) specimen by hitting the said specimen with impulse (or "knocking").
Parameters for measurement include:
- Average complex (convert from time to frequency domain with FFT)
- Hann (or Hanning) window function (this is the next parameter study, for now, bear with it)
- 20kHz total bandwidth with 25600 FFT lines (or 25.6kHz sampling rate)
Theoretically speaking, applying the low-pass filter should lead to some differences in the frequency spectrum of the transfer function. Yet, in the image below, there is practically none. Sure, there is a drop of 1~2 dB from 350 to 500 Hz, but my instructor says that this frequency range is mostly noise, and they are not as important as the peaks (where there is no significant change).
Can anyone explain this to me, why there is no difference in the spectrum?
Further check on the components also say that there is only negligible differences in both the input (knocking force) and the output (vibration). My hunch is that for the force, because I only "knock", which means there is no frequency range, and I generate the knocking signal in time domain, so there is no frequency range to block. In other words, because of my setting for the input, the filter has no effect. However, this would not explain the situation with the output and the transfer function.
Edit: Additional graph, with frequency spectrum runs from 0 to 20kHz, comparing with and without 100 Hz filter (with 3 options: No filter (black), Filter on Output only (Yellow), Filter on both input and Output (Blue))
