Let's imagine a tube that is open at one end and is filled with water. A constant source of heat is applied to a specific spot somewhere at the middle of the tube, for a example a preheated soldering iron of constant temperature. Let's say you measure the temperature of water at the upper end of the tube over a specific amount of time when the tube is parallel to the gravitational force, or 90 degrees to the horizontal. If you keep all the conditions constant, including the amount of time for heating, but change the angle so that it is 80 degrees to the horizontal, then 70, 60 and so on... You will find that the increase in the temperature becomes less as the angle decreases. But what would the graph of the increase in temperature vs sine of the angle look like? And what is the theory behind it? I undertstand that there are convection currents of natural convection caused by a buoyant force, which is caused by the difference in density and which will be counteracted by a normal force of reaction as the the tube becomes tilted. However, I would like to understand more of the physics involved in order to model the phenomenon.
The following graphs are based on primary data (collected by me). The tube used was a burette, the mark of 17 ml was in between the mark of 1 ml and the source of heat, which was at the mark of 25 ml. I realized that the wire of the thermometer at the mark of 17 ml could pose a confounding variable as it was curved, so it was not used in the fourth measurement session.
enter image description here enter image description here enter image description here enter image description here enter image description here
  • $\begingroup$ Did you factor in the heat conduction of the glass tube? $\endgroup$
    Commented Dec 11, 2020 at 20:26
  • $\begingroup$ @SolarMike No, I did not. The processing of the data only involved calculating the sine (by dividing the hight between the two ends of the tube by the length of the tube) and the increase in temperature (final temperature minus initial temperature). I would appreciate it if you refer to any literature relevant to the question. $\endgroup$
    – Alimp777
    Commented Dec 12, 2020 at 6:55
You answered the question already. In a vertical tube, water will rise and fall due to natural convection, and cause the tube to more evenly heat. This action will be much less in a horizontal tube. Simply put, in a vertical tube, the heated water can rise directly to the top of the tube, transferring energy on the way. In a horizontal tube, only small eddies will occur at the heating site, and we will depend more on conduction to heat the end of the tube.
  • $\begingroup$ What about the pattern seen in the graphs? $\endgroup$
    – Alimp777
    Commented Dec 16, 2020 at 7:13
