To obtain lateral force according to slip angles, I use Pacejka Magic Formula, but my graph's style is not similar with picture which i added. I cannot find where the mistake is.
clear all
clc
a1y=-22.1;
a2y=1011;
a3y=1078;
a4y=1.82;
a5y=0.208;
a6y=0.00;
a7y=-0.354;
a8y=0.707;
Fz=2;
Sh=-0.28;
Sv=-118;
Cy=1.5;
Dy=a1y*Fz^2+a2y*Fz;
BCDy=a3y*sind(a4y*atand(a5y*Fz));
By=BCDy/(Cy*Dy);
Ey=a6y*Fz^2+a7y*Fz+a8y;
alpha_r=-10:0.01:10;
PCKy=(Dy*sind(Cy*atand(By*rad2deg(alpha_r+Sh) - Ey*(By*rad2deg(alpha_r+Sh) - atand(By*rad2deg(alpha_r+Sh))))))+Sv;
plot(alpha_r,PCKy)
Lateral force
  • $\begingroup$ could you reference the paper where you got the coefficients and the graph? I've done enough work on Pacejka, to know that different people approach it differently $\endgroup$
    – NMech
    Dec 11, 2020 at 9:11
  • $\begingroup$ I use Wong - Theory of Ground Vehicles. I cannot add pages of the book because of copyright :) $\endgroup$
    – voo
    Dec 11, 2020 at 9:12
  • $\begingroup$ It would help if you also detailed chapter and maybe even page. $\endgroup$
    – NMech
    Dec 11, 2020 at 9:13
  • $\begingroup$ Pages 60-63 contain my problem $\endgroup$
    – voo
    Dec 11, 2020 at 9:14
The offending line was
The correct form is without the rad2deg
PCKy=(Dy*sind(Cy*atand(By*(alpha_r+Sh) - Ey*(By*(alpha_r+Sh) - atand(By*(alpha_r+Sh))))))+Sv;
if you just correct that you should get:
