Could you explain me the following convertion:
The address range is 0x00100000 to 0x1fffffff
How to convert it to bytes or Mb?
Sign up to join this communityRemember that the following number 0x123
is essentially (Starting from the last digit)
$$3*16^0 + 2*16^1 + 1*16^2 = 3 + 2*16 + 1*256 =291 $$
it is essentially the same what you are doing if you had 123 in the decimal system (just the base changes):
$$3*10^0 + 2*10^1 + 1*10^2 = 3 + 2*10 + 1*100 =123 $$
So in your case, the first number is
0x00100000
= 1*16^5 = 1048756regarding the second number I'd cheat a little bit, so 0x1fffffff = 0x20000000 -1
. So with that:
0x1fffffff - 0x20000000 -1
= 2*16^7 - 1 = 536870912-1 =536870911Since, each memory address holds a byte, then you'd be talking about a memory address from the 1st MB up to (just before) 512MB (given the convention that 1MB = 1048756 bytes)
\begin{array}{cc} & 0x &\ 1 &\ F &\ F &\ F &\ F &\ F &\ F &\ F \\ - &0x &\ 0 &\ 0 &\ 1 &\ 0 &\ 0 &\ 0 &\ 0 &\ 0 \\ + &0x &\ 0 &\ 0 &\ 0 &\ 0 &\ 0 &\ 0 &\ 0 &\ 1 \\ = &0x &\ 1 &\ F &\ F &\ 0 &\ 0 &\ 0 &\ 0 &\ 0 \\ \times & &\ 16^7 &\ 16^6 &\ 16^5 &\ 16^4 &\ 16^3 &\ 16^2 &\ 16^1 &\ 16^0 \\ \end{array}
Adding 1 goes from start to end.
$$1 \times 16^7 + 15 \times 16^6 + 15 \times 16^5 = 535,822,336\ bytes$$
0x100000 = 1MB = 1,048,576 bytes, so the address range from 0x00100000 to 0x1fffffff is 511MB.
