I am searching for an effect chain that leads to the mechanical power $P_{mech}$ of a DC motor, starting with the applied armature voltage $U_{A}$. My request also includes all the electrotechnical quantities with cause, effect and linking formula, which are created 'on the way' between $U_{A}$ and $P_{mech}$.
Thanks in advance!
  • $\begingroup$ Number of windings? $\endgroup$ – Solar Mike Dec 9 '20 at 4:48
  • $\begingroup$ I don't need calculations just the theoretical aspect $\endgroup$ – joseph Dec 9 '20 at 10:12
Some formulas for you on Wikipedia.
  • $\begingroup$ I'm searching for a specific relation between the armature voltage and the mechanical power, which I didn't find on web. $\endgroup$ – joseph Dec 9 '20 at 9:47
A DC motor is modelled as a gyrator, in which the output RPM (a flow variable) is proportional to the input voltage (an effort variable.)
As always, the input power = (flow variable x effort variable) = (current x voltage) and similarly the output power = (torque x RPM)
Mind the units.
Mechanical Power: $$P_{m} = \omega \ T_m = \frac {9.55 \ T} {n} \ \ (W)$$
$\omega$ = angular velocity in rad/s.
n = speed in rpm.
9.55 = constant to eliminate 2𝜋 radians and 60s/min.
Torque: $$T_m = k_b\ I_a\ -\ T_f \ \ (N \cdot m)$$
$k_b$ = torque constant in N•m/A.
$I_a$ = armature current.
$T_f$ = motor friction torque in N•m.
Armature Circuit KVL:
$$U_a = I_a\ R_a -\ U_b \ \ (V)$$
$V_a$ = armature voltage.
$I_a$ = armature resistance in Ω.
Back emf:
$$U_b = k_e\ \omega \ \ (V)$$
$k_e$ = back emf constant in V•s/rad.
