This eccentric bushing:
belongs to the hand crank of this machine:
It cannot be seen clearly in the photo, but the small blocking bar inside the bushing is not hovering over but rather, is sunk into a notch in the same surface which contains the thread.
I would like to disassemble the bushing, because the crank is badly aligned. How can I do this? Should I remove the small blocking bar inside in order to disassemble? Do I need a special tool?
  • $\begingroup$ to me it looks like a shaft key $\endgroup$
    – NMech
    Dec 7 '20 at 15:23
  • $\begingroup$ May have to temove the assembly to get to the bearing. Given this is the second question you have about this machine, perhaps you should find a workshop manual for it. $\endgroup$
    Dec 7 '20 at 15:25
  • $\begingroup$ @SolarMike This boltontool.com/pdf/SBR1220.pdf is the only manual which I have found: for a machine which "looks similar". It is silent about these bushings. Do you mean that I should take a large wrench and try to pull out the thing? $\endgroup$
    – scriptfoo
    Dec 7 '20 at 15:56
  • $\begingroup$ What do you mean by "badly aligned"? That's just a key, so there should be nothing (except friction) stopping you from pulling the handle off the shaft... $\endgroup$ Dec 7 '20 at 17:41
  • $\begingroup$ @JonathanRSwift After your comment I understood what's going on, wasn't afraid to use a hammer (a wrench wasn't enough) and pulled it off. $\endgroup$
    – scriptfoo
    Dec 7 '20 at 20:01
