I am working on a personal project where I need to select a motor to rotate a system that is in static equilibrium. The motor torque specification is given in kg.cm.
This is what I have: Bar : 2 meters in length, weighing 1kg (for simplicity) Axle: 10mm (5mm radius) with a bearing to reduce friction. F : F1 and F2 both weigh 10kg
(F1) (F2)
10kg 10kg
-------o-------
T1 -T2
I am not entirely sure what all the parameters are to arrive at a formula to use. Also, what formula can I use to calculate the torque required to rotate the system at a constant speed of 3rpm ?
Thank you in advance.
