is there any provision in SolidWorks to check if all parts in an assembly is assigned material, rather than individually checking each part under the design tree? It becomes tedious to check individually when there are too many parts
  • $\begingroup$ Define the material for each part as the part is defined then they are complete. $\endgroup$
    Nov 27 '20 at 21:15
    $\begingroup$ Insert a BOM and add a column for the material - will quickly see where the blanks are $\endgroup$ Nov 27 '20 at 21:57
